How Much Will Performance Drop?
Go to solution Solved by miyabwah,
Yes it will.
So I did a benchmark of DiRT 3 in 1080P and 768P.
MSAA was 4X, and most settings were on high except for post processing.
My results were :
768P
Minimum : 70.07 FPS
Average : 82.30 FPS
1080P
Minimum : 102.60 FPS
Average : 120.27 FPS.
Which means : 70.07 ÷ 102.60 = 68.2943469785575%. That means that 1080P performance is 68.2943469785575% the performance of 768P, at MINIMUM framerates.
And for averages, 82.30 ÷ 120.27 = 68.42936725700507% That means that 1080P performance is 68.42936725700507% the performance of 768P, at AVERAGE framerates.
Keep in mind, this was one benchmark and I can do more if needed.
Right now I'm running at a resolution of 1360*768. In December I plan on upgrading to a 1080P monitor. I can play all my guys maxed, including AA with over 60 FPS. My specs are in my signature. How much will performance drop going to 1080P? Thanks.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/230979-how-much-will-performance-drop/
If i did the math right, your resolution is about 50% as much as 1080p.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
Do you think I can turn down AA and get better performance and not really notice it because of the higher resolution?
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
your signature size is against the CoC, max font size is 14
thx :)
Yes it will.
My results were :
768P
Minimum : 70.07 FPS
Average : 82.30 FPS
1080P
thx :)
Apologies, I'll fix that.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
@Lanoi Thank you so much, that was very helpful.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
