Bug with my posts?
Go to solution Solved by colonel_mortis,
If a post has no replies, for some reason it seems to appear to have no views (at least sometimes). This is an inherent bug in the forum software that we're using, but will probably be fixed when we update to the next version next year (it will probably be around Q2 2015, but that is subject to change).
Hi guys!
When i post something on the forum i see that people are viewing it but i don't get a replie.
Yesterday i posted this in the Audio section and it says that it has 0 views and 0 replies. It was viewed, sometimes 6 people that the same time.
Is this a bug or am i shadowbanned or something? :P
And yes.. i follow my posts..
Thanks!
Let's just hope i can get replies to this one
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/229549-bug-with-my-posts/
Hi guys!
Thanks!
It's a bug.
Also, +1 for daft punk
https://linustechtips.com/topic/229549-bug-with-my-posts/#findComment-3141763
What's Shadowbanned?
On Reddit when you are shadowbanned you can still post and stuff but nobody can read it. You don't even know you're banned
https://linustechtips.com/topic/229549-bug-with-my-posts/#findComment-3141777
Now comes the question, does this same thing happen with this post? :P
I checked, it didnt! ;D don't know why tho!
https://linustechtips.com/topic/229549-bug-with-my-posts/#findComment-3142805
HTTP/2 203
https://linustechtips.com/topic/229549-bug-with-my-posts/#findComment-3142950
i got the same thing on one of my topics, does that mean i can re-post it?
Edit: okay... it's lonely there...
Build: Sister's new build |CPU i5 2500k|MOBO MSI h61m-p23 b3|PSU Rosewill 850w  |RAM 4GB 1333|GPU Radeon HD 6950 2GB OCedition|HDD 500GB 7200|HDD 500GB 7200|CASE Rosewill R5|Status online
Build: Digital Vengeance|CPU i7 4790k 4.8GHz 1.33V|MOBO MSI z97-Gaming 7|PSU Seasonic Xseries 850w|RAM 16GB G.skill sniper 2133|GPU Dual R9 290s|SSD 256GB Neutron|SSD 240GB|HDD 2TB 7200|CASE Fractal Design Define R5|Status online
https://linustechtips.com/topic/229549-bug-with-my-posts/#findComment-3143123
Alright thank you very much!
https://linustechtips.com/topic/229549-bug-with-my-posts/#findComment-3143487
