So I have a few different questions but first look down in my signature to see what I'm upgrading from. Also I will not be upgrading the GPU immediately. Now time for questions:
1. Processor: i5-4690k or FX-8320?
2. GPU: R9 285, R9 280, or GTX 770?
3. Motherboard (only applicable if Intel build): MSI Gaming 7 or MSI Gaming 5?
I'm trying to keep this system as cheap as possible while still maintaining better performance than my current build. I will be Recording/Uploading videos and playing a ton of games on this thing.
(Yes I know that the GTX 970 is out but its a little above what i want to pay for a GPU right now.)
Youtube Channel: youtube.com/ExoGamer0529
https://linustechtips.com/topic/229422-gamingrecording-build-help/
1) 4690k
2) GTX 970 (unless you cant afford it, what's your budget?)
3) look at the feature list and decide if the 7 is worth your extra money
As for the processor, from your options I would go with the I5, Although there are many better i7 Processors which will help with recording.
For your graphics card once again from your options I would go with the 770 but for a budget build the 780 wont do much harm.
For the motherboard get the gaming 7.
CPU: I7-4790k CPU Cooler: NZXT Kraken X61 Motherboard: Gigabyte GA Z97X-Gaming 3
Ram: Kingston HyperX Fury Black 1866 16GB, (2x8GB) GPU: Gigabyte Geforce G1 Gaming 980Ti
Case: NZXT Noctis 450 (Black/Red) Storage: Samsung 850 Evo 250GB SSD, Seagate Barracude 7200RPM 3TB
PSU: Seasonic 750W 80+ Gold
Im looking at the 200-300 dollar price range on the graphics card and I have and its really just a few extra SATA Ports that I would get, I could use them but probably won't I'll be building in an NZXT H440.
EDIT: I'm not sure that there is an unlocked i7 for the LGA1150 socket that is sub-$240.
For Capturing...This can play a part in your decision.
If you like tinkering around WITHOUT GETTING PISSED OFF when it doesn't work cos it's BETA...
Then Performanice of the R9 290 +>Beta Capturing AMD Game DVR Program (Raptr)
^I know it works, I use it, but it records in VFR and program DOES have random ass Beta issues.
Easy method to capture.
Or the GTX 770 + Shadowplay
^Works a treat, simple to use and records in CFR
Or use the CPU to record like most people, take a performance hit and choose what you think is best anyway.
CFR - Constant Frame rates
VFR - Variable Frame rates
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
