so I have been pondering over what cases to get, not liking something about the case, or seeing a case I like, ordering it, then seeing an even better case (frustrating ugh)
so I've been thinking, how about making a custom case?
Now I have a lot of tools to my disposal, and materials are not an issue. I've seen a lot of computers put in there desks, and that looks pretty cool, but I've been wanting to do something different but I am not sure what. I am probably gonna think about it more, but  little ideas from other people could help shape maybe one of the coolest cases ever.
lets-do-it1.gif?w=584
https://linustechtips.com/topic/228884-custom-case-ideas/
A chair case. You sit on your computer.
You can sit on an old Antec case with a cushion on top :P.
guess i kinda left out the size eh, ahaha but i was thinking of doing just an ATX build
You can do a inverted  90°-rotated ATX case, like a Silverstone TJ11 but without being massive. Make it space efficient, ditch the hard drives and go for a huge bottom intake paired with a rear exhaust. You can mount the PSU vertically behind the front panel which would be clean with a design/logo. Leave enough space for radiators, res and pump, so if you want to venture into watercooling the case will support it.
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3132670
Unless you have access to a laser cutter or CNC machine I would not try making a case from scratch.
It will be a lot of work for something that turns out worse than the stuff you could buy from caselabs or something...
But if you're determined and don't mind spending money on a project like this, then go for it :)
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3132707
pretty much my tools consist of a plasma cutter, iron-worker, shearer, hydraulic bending machine, pretty much things to make clean bends and cuts if I wanna use steel, or if I use plastic I mean I have other things, and my material is all free from where I work
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3132795
Like ft05
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3134170
Oh then it sounds possible for you then :)
Do a build log
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3134666
I'd honestly never thought of that.
I'd just do something that has a good industrial look with a lot of fans. Instead of doing quad 120's do quad 140's etc.
I'd make something similar to that, but with 140's on the side, another set of side fans on the top, with another set of fans on the "roof" so that the top rads would be intaking and then immediately exhausting out of the roof. Then have dual rear 140's on the back, and 4 vertical 140's on the front intaking. On the bottom I'd have 2 rads on either side intaking with another set of fans above them pulling the air into the main chamber to be exhausted by the rear fans. Then have a UV reactive plexiglass (semi transparent, like the UV reactive lego blocks) with hidden UV lighting to make the case seem to glow on it's own. Color scheme could be whatever.
Dubs are better than subs
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3134708
@OP, I just noticed your username... What about a PC in a barrel? Make it look like an exaggerated IED?
Like this one?
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3134739
A very very very horribly crude paint drawing of my idea for a case. Fan sizes and rad sizes could of course vary, but I'd like to see it done and plan on doing one like this myself some day. View is from the front, not the side.
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3134792
Do one themed around your favourite videogame :D
My dream PC is a Starcraft 2, Zerg themed PC, which I would name Hive Mind
CPU: Intel Core i7-4770k | Mobo: MSI Mpower Max | Cooling: Cryorig R1 Ultimate w/ XT140 front Fan | GPU: EVGA GTX 770 Dual SC SLI | Case: NZXT H440 | Case Fans: Phanteks PH-140SP x5 | PSU: EVGA Supernova P2 1000W | RAM: 16GB Crucial Ballistix Tactical Tracer | SSD: Kingston HyperX 3k 120GB | HDD: Seagate Barracude
Keyboard: Razer Blackwidow Ultimate 2013 | Mouse: Razer Deathadder 2013 | Headphones: Sennheiser HD438s | Mousepad: Razer Goliathus Control | Monitor 1: Benq XL2430T | Monitor 2: BenQ RL2455HM
https://linustechtips.com/topic/228884-custom-case-ideas/#findComment-3134866
