Which sound device should i use? Sound card or Onboard?
I heard him typing with my bare ears....
He heard you typing that across the country with his 1337 audio setup
I'll re-ask my question:
If, for example, you like the sounds from the Realtek more than the SB, but it turns out the SB is better on the paper. Would you switch to the one you like less, just because it's statistically inferior (not because you dislike it)?
Well then, guess I was wrong... it's not about what he hears as better, it's out of curiosity. That makes sense too.
I can't really tell a difference. Therefore i am wondering which one is supposed to be better?
With no usable specs for the Recon and Realtek performance changing from motherboard implementation to motherboard implementation, it's hard to tell you. I would suggest taking out the sound card and just using onboard.
