Would dry ice in front of a computer intake vent work or would it cause condensation?
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/224271-dry-ice/
i would worry about condensation, yeah
and dry ice is fucking dangerous man you can't just have some lying near you in front of the PC
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072116
Could cause condensation if the air has moisture in it and is colder than outside the case I would imagine.
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072118
It's dry ice... I'm no expert but for one that is a terrible idea and two It shouldn't cause condensation as long as the room temperature isn't too far off compared to the ice temperature. In other words don't do it.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072123
Just thinking, not wanting to do it just thinking. Also thought about ducting a AC vent from the floor to the case (Prob not a good idea). No, what I'll do someday when I get money is get a external rad and stick it on the wall.
| F@H STATS |
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072154
I actually wouldn't imagine it would cause a problem. I don't think case fans have enough "air-moving" power to move enough chilled air inside the case to lower the temp enough to cause condensation. Although I probably wouldn't be comfortable doing it anyway.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072172
It's just cold CO2. Just have plenty of ventilation and don't touch it with your bare hands and you'll be fine. It's not like sodium in water...
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072248
I made bombs with it once. It was awesome.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072268
I've picked up dry ice bare handed, didn't see what the big deal was, granted I did not hold it very long, wasn't about to tempt fate.
It felt cold to me, but no colder than regular ice.
Dubs are better than subs
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072305
what is dry ice?
Dry ice is frozen carbon dioxide. A block of dry ice has a surface temperature of
-109.3 degrees Fahrenheit (-78.5 degrees C). Dry ice also has the very nice feature
of sublimation -- as it breaks down, it turns directly into carbon dioxide gas rather than
a liquid.
https://linustechtips.com/topic/224271-dry-ice/#findComment-3072423
Why the hell do you even want to do this in the 1st place?
 Motherboard  ROG Strix B350-F Gaming | CPU Ryzen 5 1600 | GPU Sapphire Radeon RX 480 Nitro+ OC  | RAM Corsair Vengeance DDR4 3000MHz 2x8Gb | OS Drive  Crucial MX300 525Gb M.2 | WiFi Card  ASUS PCE-AC68 | Case Switch 810 Gunmetal Grey SE | Storage WD 1.5tb, SanDisk Ultra 3D 500Gb, Samsung 840 EVO 120Gb | NAS Solution Synology 413j 8TB (6TB with 2TB redundancy using Synology Hybrid RAID) | Keyboard SteelSeries APEX | Mouse Razer Naga MMO Edition Green | Fan Controller Sentry LXE | Screens Sony 43" TV | Sound Logitech 5.1 X530
https://linustechtips.com/topic/224271-dry-ice/#findComment-3073271
Lol I did it in a vally, it must have echoed for miles. Way better than coke and mentos.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/224271-dry-ice/#findComment-3073753
yeah :P
One "exploded" in my friends hand. I ways like half a foot away. It was awesome.
https://linustechtips.com/topic/224271-dry-ice/#findComment-3074887
Forgot the "condensation" part.. You could make an intake where air is sucked in through dry ice. It will then freeze out all the moisture out of the air. This would require larger quantities of dry ice and intake fan that can handle operation in -50C to -80C. There would be other problems like icing from the air already present in the case.. But then you could start by pumping clean nitrogen first to displace the air inside the system.
https://linustechtips.com/topic/224271-dry-ice/#findComment-3075391
What I remember from handling dry ice almost barehanded (with really thin gloves) and with good gloves, it doesn't really make air that much colder. It has more effect on water and matter that has high concentration of water like lake soil sediments (for which we used it).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/224271-dry-ice/#findComment-3076636
