Corsair 450D?
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/221965-atx-case/#findComment-3042466
price range?
Looking for anything specific? such as cable management, side window, USB ports, x amount of HDD trays etc
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
https://linustechtips.com/topic/221965-atx-case/#findComment-3042475
Why did you repost??
Because you're a newbie here at LTTF, maybe we'll let it slide, just this once.
​*sarcasm detected*
But yeh, as @ZacDaMan72 mentioned, the 450D will probably be the best option. It doesn't exceed 500mm in height or length, but is still able to hold an ATX motherboard.
Also, welcome :D
Be sure to read the CoC and stickies in subforums, also use the quote function so that the person you are replying to gets a notification that you replied to them.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/221965-atx-case/#findComment-3042482
The NZXT S340 would be my pick as it looks brilliant and is cheaper than most cases that have half its features.
http://www.nzxt.com/product/detail/151-s340-mid-tower-atx-case.html
Bitfenix Neos wouldn't be too bad either
http://www.bitfenix.com/global/es/products/chassis/neos
https://linustechtips.com/topic/221965-atx-case/#findComment-3042505
Go with the 450D :P
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/221965-atx-case/#findComment-3042622
my price range is on more than $200
Ft04/ft02/ (best option) ft05
https://linustechtips.com/topic/221965-atx-case/#findComment-3045446
If that's how high your price range is, get the FT02/05 as @spwath said, as those, along with the RV05 are the best air cooling cases you can buy outside of a test bench. However if you want something a bit more "normal" then the phanteks enthoo luxe and corsair 760/780t are good choices IMO but a little big most likely. The fractal design arc midi r2 is pretty small, as is the 450D and they are good cases.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/221965-atx-case/#findComment-3046419
