1440p IPS monitor
Killswitch49
My search for a 1440p IPS monitor has not turned up many successful results. Yes I know you can buy the Korean monitors but I want one from a brand I trust and a retailer with solid customer support (btw I live in Canada so no microcentre or any of that jazz). Anyway most important for me is the quality of the panel. I want it to have minimal colour bleed and very good colour depth (more important than 120hz) as I will be mostly watching movies on it. Thx
i5 4670k / Be Quiet Dark Rock Pro 3 / Asus Maximus vi hero lga 1150 mobo / Sapphire tri-x r9 290 OC edition / corsair vengeance pro red 4 x 4 gb 2133mhz cas 9 ram kit / nzxt phantom 530 black / 120gb samsung 840 evo ssd / 240 gb ocz arc 100 ssd / 2x 1tb WD Blue / Cooler Master v850 modular psu / corsair k70 rgb cherry mx Brown / mad catz rat 5 laser mouse / windows 10
Do you live close to the border?
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I've had my Asus PB278Q for a year now and I've had no problem with it.
CPU Intel i7 3770K | Motherboard ASUS Z77 Sabertooth | RAM G.Skill Ripjaws Z 16GB(4x 4GB) | GPU ASUS GeForce GTX 680 DirectCU II TOP | Case Thermaltake Overseer | Storage Samsung SSD 500GB 850EVO, WD Caviar Black 1TB | PSU Cooler Master Silent Pro M2 Series 1000W | Display(s) ASUS PB278Q 27", 2x Samsung LS22C45KBW 22" | Cooling Corsair Hydro Series H75 | Keyboard Razer Lycosa | Mouse Razer Lachesis | Sound Dell speakers a525 2.1, Razer Kraken 7.1 | Operating System Windows 7 Professional
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
240Hz PWM flickering backlight, 800:1 contrast ratio, 1 frame input lag... come on, there's better options today for that price.
FYI, it's been at $530 for the past four months. Plus, it causes headaches if you're sensitive to led pwm dimming. People keep recommending this monitor on here like it's some sort of holy grail... There's much better options out there.
i7 7700k @ 4.9ghz | Asus Maximus IX Hero | G.skill 32gb @ 3200 | Gtx 1080 classified | In win 909 | Samsung 960 pro 1tb | WD caviar blue 1tb x3 | Dell u3417w | Corsair H115i | Ducky premier dk9008p (mx reds) | Logitech g900 | Sennheiser hd 800s w/ hdvd 800 | Audioengine a5+ w/ s8
Thats PLS
I hope you're trolling?
Display Screen Size 27" LED Backlight Yes Widescreen Yes Recommended Resolution 2560 x 1440 Viewing Angle 178° (H) / 178° (V) Pixel Pitch 0.233mm Brightness 300 cd/m2 Contrast Ratio 80,000,000:1 Response Time 5ms (GTG) Panel PLS Display Type WQHD  Source: http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236294&cm_re=pb278q-_-24-236-294-_-Product
PLEASE USE PCPARTPICKER.  My rig: http://pcpartpicker.com/p/ZBmWjX
You're clueless, man.
Was there a revision of the monitor that i've missed. Ik PLS is in the IPS family.
Edit: I could be very wrong though. I have been known to be quite wrong sometimes.
Not that I'm aware of.
While strictly not an IPS panel variant, we have included PLS in this section since it is IPS-like in character and performance. PLS was introduced by Samsung at the end of 2010 and designed to compete with LG.Display's long-established and very popular IPS technology. They claimed they had reduced production costs compared with IPS by about 15% and so were making a play at the market of IPS panels. At the time it was also being dubbed "S-PLS" (Super-PLS) but that name seemed to be dropped quite quickly in favour of just "PLS". It wasn't until mid 2011 that the first PLS screens started to appear, fittingly they were manufactured by Samsung themselves. The Samsung S27A850D was the first of its kind and its overall performance certainly reminded users of IPS panels.
Response times are quite comparable to IPS matrices, with 5ms G2G being the current lowest spec on paper. There is currently no support for refresh rates about 60Hz, although there are some Korean manufactured screens which can be over-clocked to 100Hz refresh rates. This is not natively or officially supported though. Contrast ratios are typically around 700 - 900:1 in practice, although can reach up to 1000:1 in some cases as per their spec. Viewing angles are very comparable to IPS as well with wide fields of view and freedom from the off-centre contrast shifts you see from VA panels. From a wide angle dark content has a pale / white glow to it like modern IPS panels, again leading to a fair amount of so-called "PLS-glow" which can be distracting to some users.
Thats PLS
PLS is close enough to IPS that it's still worth recommending for someone who wants an IPS monitor? It's just Samsung's version of IPS.
The contrast ratio is 80M:1, not 800:1 - big difference.
What are the better options for the money? Just curious. I only recommended the PB278Q because I've heard good things about it from pretty much everyone.
I found these ones on NCIX, would you recommend these over the PB278Q?
http://www.ncix.com/detail/benq-gw2765ht-27in-ips-wqhd-d6-98207-1343.htm
http://www.ncix.com/detail/benq-bl2710pt-27in-wqhd-2560x1440-ca-85053-1028.htm
Static contrast ratio is 1000:1, dynamic contrast ratio 80m:1.
The bl2710pt doesn't use pwm dimming and is superior to the asus pb278q. Here's an excellent review by NCX.
I would avoid this sub-forum all together because you'll get a lot of clueless kids that give you opinions on stuff they literally know nothing about. http://hardforum.com/forumdisplay.php?f=78 TFTcentral/Prad.de are much better alternatives.
Edited for typos
Edited by eLucid
I do I live in Toronto and I am going to New York in a few weeks. Are there any stores there?
- Source http://www.tftcentral.co.uk/articles/panel_technologies.htm
Edited for typos
alright I think I'm going to go for that monitor and I will try that forum also thx for all the help guys
after further inspection it seems that the monitor has noticeable problems with such as colour bleed and some colours not appearing correctly (darks,reds and greens). Again most important to me is the panel quality
I would avoid this sub-forum all together because you'll get a lot of clueless kids that give you opinions on stuff they literally know nothing about. http://hardforum.com/forumdisplay.php?f=78 TFTcentral/Prad.de are much much better alternatives
Who are these "clueless kids" you're referring to? :huh:
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
Check around online as well as eBay. You can find excellent deals on a lot of monitors.
