Hi guys so I found some standard components for my first build and I was wondering if the watt would be enough. My watt size is 600.
My first pc spec build:
Arctic Cooling Freezer 7 Pro rev 2
Crucial 4GB DDR3 1600MHz Ballistix Sport VLP x2
Gigabyte GTX 650 4GB GDDR5 VGA Dual DVI HDMI PCI-E Graphics Card - 400 watt
MSI B85M-G43 Socket 1150
Crucial MX100 128GB
WD 1TB Blue Desktop Drive
Samsung SH-224DB 24X Internal DVD Writer with SATA - OEM
CIT Gold 600W Fully Wired Efficient Power Supply - I will change only for the watt size
Titanium 500 ATX PC Gaming Case
Intel Core i3 4130
TP-Link 300mbps Wireless N Pci Express Adapter
Please note that I am happy with this spec as I don't want to changing about it but only the power used
Thank you.
https://linustechtips.com/topic/219859-what-watt-do-i-need/
you need the standard watt, not the aftermarket watt. :3
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013699
What what, what what bud dun dun nana roll up to the thrift shop
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013711
Wat? puns aside i legit dont know what your asking
 The Wannabe is no longer. Replaced by the Flotilla. If you replace every part of a computer is it still the same computer?
Survived the Survivor 2299
Audio Engineer, Lighting Programmer, Video Engineer, FOH.
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013724
Thank you.
http://linustechtips.com/main/forum/21-cases-and-power-supplies/
http://linustechtips.com/main/topic/199255-how-many-watts-do-i-need-check-here/
600 watt is much more then what you need, but it's a matter of how many watts your PSU can actually put out. Considering it only has a single 6 pin PCIe power connector, not 600 watts.
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013737
Output 28A 30A 14A 13A 0.3A 2.5A
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013762
That's just what the sticker says. What's in the power supply is likely a whole different story.
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013764
well here is the spec for psu
  • Dual 12v Rails
  • Cooling: 12cm Silent Fan
  • New Version Ver. 2.2
  • Silent and Better Ventilation
  • ATX 12V Compliant for all Types of CPU and Mainboard
  • AC INPUT: 230 VAC 5A 50-60Hz
  • DC +3.3V +5V +12V1 +12V2 -12V +5VSB
  • Output 28A 30A 14A 13A 0.3A 2.5A
  • Max 600W
  • 20+4 Pin Main Connectors:1
  • 4-Pin 12V Connectors:1
  • SATA Connectors:4
  • 4-Pin Molex Connectors:4
  • 6-Pin PCI-e Connectors:1
  • Floppy Drive Connectors:1
  • Dimensions: 150mm x 85mm x 158mm (W x H x D)
  • Input Voltage: 230 VAC
  • Input Current: 5A
  • Input Frequency Range: 50-60Hz
  • PFC: PPFC
  • Power Good Signal: 150-450 ms
  • Hold Up Time: 1ms-40ms
  • Efficiency: 75%
  • MTBF: 100,000 Hours
  • Protection: OVP / UVP/OPP
  • Power: 600W
  • Operation Temperature: 45°C
  • Safety: CE / ROHS
  • Cooling: 12cm Fan
  • Noise: < 17 dBA
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013775
-snip-
Again, that doesn't state anything useful. There's a lot more to a PSU then the generic specs. When looking for a PSU, you'll want a reputable one with high quality components. Good caps, line filtering, voltage regulation, and ripple are things that you'll want to be looking for.
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013788
oh right thanks
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013793
oh right thanks
Also, the company that actually makes the PSU is very important (not the brand name of the PSU). High quality PSU OEMs like Seasonic, Super Flower, Delta, and Flextronics are recommended.
https://linustechtips.com/topic/219859-what-watt-do-i-need/#findComment-3013815
