What exactly is a "reference" card?
A proper reference card is a card that is exactly like Nvidia designed it.
Nvidia's PCB
Nvidia's cooler
Stock clock speeds
An overclocked reference card.. or in this case "superclocked"
, is a card with:
Nvidia's PCB
Nvidia's cooler
Higher clock speeds than the 100% reference design
Just a little extra rambling here
What I call a sub reference card (some people say aftermarket but I don't consider these truly aftermarket) is a card with:
Nvidia's PCB
Aftermarket cooler
Stock or higher clock speeds
What I call a truly aftermarket card is a cade with:
Aftermarket PCB
Aftermarket Cooler
stock or higher clock speeds
Honestly, it depends what you as a person see as reference. Some people will say it's a reference card that's been overclocked while other may say it's not a true reference card.
That kinda swayed from what you wanted to hear... hmmm. ![]()
TL;DR
Yes, this card uses a reference PCB.
