Need help making a 4k gaming/ rendering PC
Solved by JuTheBarbarian,
Here's what I came up with ....
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor ($605.99 @ DirectCanada)
CPU Cooler: NZXT Kraken X41 106.1 CFM Liquid CPU Cooler ($99.99 @ Memory Express)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard ($417.93 @ DirectCanada)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR4-2400 Memory ($259.98 @ Newegg Canada)
Storage: Crucial MX100 512GB 2.5" Solid State Drive ($224.99 @ Amazon Canada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($84.98 @ DirectCanada)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card (2-Way SLI) ($702.84 @ Newegg Canada)
Case: NZXT Phantom 630 Windowed Edition (White) ATX Full Tower Case ($189.99 @ Memory Express)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($126.99 @ NCIX)
Operating System: Microsoft Windows 7 Professional SP1 (OEM) (64-bit) ($149.97 @ DirectCanada)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard ($114.99 @ Canada Computers)
Mouse: Logitech G600 MMO Gaming Mouse Wired Laser Mouse ($64.99 @ NCIX)
Total: $3916.43
Generated by PCPartPicker 2014-09-20 16:19 EDT-0400
I got rid of the second solid state drive because 512GB is enough for what you want to do and after that I simply added another 2TB HDD for extra storage.
As far as the graphics cards go, with the rate of diminishing returns I just will never seem to recommend a 3-way SLI setup, especially when you can simply get 2 more powerful cards which will probably yield better performance (with less diminishing returns) while costing you less in your electricity bill. The less graphics cards you can get away with, the better things tend to be methinks....
As far as the Processor I beefed it up to a 5930k, it has the same amount of cores as the 5820k but the cores work faster which should help in gaming and rendering performance (it seems to be a good blend of both).
For the RAM I removed the 2nd 16GB kit and just left you with 1 16GB kit. A smooth gaming experience only requires 8GB of RAM, while most people using computers for professional applications (rendering and the like) mostly recommend 12GB. So 16GB should be more than enough. (Also note the fact that I'm pretty sure these recommendations were made for DDR3 RAM and your are using DDR4 which is much faster than DDR3.)
As far as the OS goes, I myself would go with windows 8.1 but at this stage it's more of a preference thing really. I would recommend however that you either get it from Microsoft directly or pick it up in a computer supply store. I've heard that some sites that claim to sell it for a really cheap price don't give you legal copies as the are simply not legal retailers for windows.
Anywhoo, that's what I'd do. I hope this helped you out!!!!
