well just to get this out of the way... the psu was on sale and cheaper than the 850w one...
But the question is...  the pcie cables are splitttet so that you got two 6+2 pin conectors on the gpu side.... since this psu has quit a good amparage per pci chanell. vould i run grapichcards of one cable? I am waiting for the gtx 980 to be released.
https://linustechtips.com/topic/216832-cooler-master-v1000-cables/
You need to plug in as many as the GPU has on it
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
A modern gpu usualy uses two either 8 pin or 6 pin. my cable has two 6+2 pin on the same cable.... so technically i could power up a card with only one cable... But yeah. you didnt really answer my question
If the GPU has 2x6-pins you need to plug in 2x6-pins. You can not plug in just one.
it should be fine i run my r9 270x overclocked off a single cable with two plugs. some power supplys only have one cable with two plugs and they are perfectly happy running titans and 780tis
Yes, if they cable has two plugs on one cable it will work otherwise no.
Yes, it wood be fine
Still one cabel... if you read what i wrote i asked if i needed two cabels from different circuts on the psu to run a card. or one would be sufficint if it looks like the picture i posted...
Ok.. here is a picture.. since no one understantds what i mean by 2x 6+2 cable... will one of them be enough for one card? if i remember right the pci rails has 82 amps or something like that....
Yes you can just use that one cable and plug each connector into the gpu connectors.
Hi Zikky. The fine folks above have answered the question I'm interpreting from your original post.
Your question: Can I use a single PCIe power cable that has two 6+2pin connectors from my V1000 to power a single GPU that has one of the following power connection setups?:
  • Two 8pin connections
  • Two 6pin connections
  • One 8pin connection and one 6pin connection
Answer: Yes. The single cable is able to power a modern GPU with any of those connection requirements. That is why these PCIe cables are designed with the two 6+2pin heads.
If I misunderstood anything, please do explain further so we can be clear and help you answer your question :)
Cooler Master USA representing! Looking for help? Head to the CM Fanzone to get in touch with the Customer Support team!
That answered it. I was offshore at the time i posted this... so it kinda got messed up due to bad connection. so didn't read the reply.
