Hi guys,
Let me explain whats going on:
I use a astro mixamp to route all my console audio(Xbox 360, Xbone, PS4, Ps3) via optical to my headphones via a mixer, and I have it plugged into my PC via usb to use as my primary PC headphones as well.
My issue: I hear a very audible humming from the mixamp.
I have found a solution: Power the mixamp via a apple 2-prong USB charger.
Since that works, its leading me to believe that there is a grounding issue either from my PC's PSU, or something else to do with the USB ports.
Any help or tips are greatly appreciated. If you need me to clarify further, I would be happy too.
Thanks,
-Shrimp
Gaming PC: CPU: 4770k @ 4.0Ghz GPU: Gigabyte G1 Gaming GTX 980 RAM: 16GB Corsair vengeance 1600Mhz Mobo: ASRock Extreme 9/AC PSU: Corsair AX760i Case: Corsair 750D CPU Cooler: Corsair H100i HDD: Samsung EVO 250GB, 1TB HDD, 4TB HDD
https://linustechtips.com/topic/215955-astro-mixamp-grounding-issue/
Hi guys,
Thanks,
-Shrimp
try a different usb cable, the one astro includes is very low quality.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
OK, ill give that a go and report back!
EDIT: The cable astro includes is like 10 feet long, that probably does not help.
