I'm planning to overclock my 3770k to around 4Ghz, but I will trash the stock cooler that comes with it, and want to purchase an aftermarket cooler (air or liquid, doesn't matter) for around 50 bucks. Any suggestions? And also, is 4GHz a realistic aim for a 3rd gen. 3.5GHz processor? Thanks.
https://linustechtips.com/topic/215939-recommend-a-cpu-cooler-for-overclocking/
4GHz shouldn't be a problem, the 3770K running at stock will turbo up to 3.9Ghz anyway...  you could even get away with it on stock cooling if you really wanted to, you won't even have to increase the voltage.
The cooler master Hyper 212 EVO is a good cooler that is capable of a mild overclock. If you want to go more extreme the noctua nhd-15 is a good choice.
beQuiet Shadow Rock 2 would fit your budget. Also, like @simtransporter said, 4GHz is nothing. 4.5 should still be easy.
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
Enermax ETS-T40 is probably your best bet at this budget. There is also a white and black with blue led version if you like.
It all comes down to the silicon lottery, the average 3770k can achive about 4.2 GHz with an air cooler of this performance level. You might get more, you might get less, there is only one way to know for sure: Try it! ;)
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
Just get the 212 evo, you should be able to get about 4.2 out of it with that cooler I think.
I have my 3770k at 4.6 using a NH-u14s
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
