First PC Build! Need opinion and help!
Solved by CowsGoRoar,
I heard that this CPU had better Overcloking capabilities. Should I get the i5-4690K instead ???
Yes, I'm glad you switched for an i5. You will not regret it, I have a 4770K and I regret it, I really should have got the i5.
The current plan is perfect. Nothing else to change
Featured Topics
ImMiles ·
Posted in New Builds and Planning2 -
D-pacman ·
4
generic000 ·
Posted in Graphics Cards9 -
Cringe_Master245 ·
Posted in CPUs, Motherboards, and Memory1 -
Rideonbrother ·
Posted in New Builds and Planning1 -
3
play_circle_filled
Latest From ShortCircuit:
I'm a Huge Sucker for a Cool Gimmick - Epomaker DynaTab 75X & DynaTab 75
play_circle_filled
Latest From Mac Address:
The Apple Vision Pro Leaves a Mark (but not the right kind)
