First PC Build! Need opinion and help!
Solved by CowsGoRoar,
I heard that this CPU had better Overcloking capabilities. Should I get the i5-4690K instead ???
Yes, I'm glad you switched for an i5. You will not regret it, I have a 4770K and I regret it, I really should have got the i5.
The current plan is perfect. Nothing else to change
Featured Topics
INotPablo ·
Posted in New Builds and Planning1 -
1
EdoTensei ·
Posted in Graphics Cards2 -
Idkwhattodowithmylife ·
2
1
1
