phanteks enthoo pro
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2947327
Corsair Carbide Air 540. Best for airflow, and super awesome cable management,
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139022
No drive cages in the way of the front fans. Can take three 120mm fans on the front, or 2 140's, along with a 120 or 140 on the back, and twin 120's or twin 140's on the top. For only $129 USD.
Dubs are better than subs
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2947493
Like the others said, the Corsair Carbide 540 is great for air cooling. The Silverstone Raven RV03 has really good airflow as well but for a slightly higher price tag.
ITX Build: CPUIntel i7 6700K MoboAsus Maximus Impact VIII | MemoryCorsair Dominator Platinum 16gb GPU: EVGA GeForce 980 Ti Hybrid | PSU: Corsair AX1200i | StorageSamsung 850 Evo 1tb SSD, WD Red 4tb HDD EnclosurePhanteks Evolv ITX (white) | Cooling: Corsair H100i | Case Fans: Noctua Industrial PPC PWM NF-F12 and NF-A14
ATX Build (in progress): CPUIntel i7 5960X MoboAsus Strix X99 | MemoryCorsair Dominator Platinum 32gb GPU: TBD | PSU: Corsair HX1000i | Storage: Samsung 950 M.2 512gb, Samsung 850 Pro 1tb SSD, WD Red 4tb HDD, WD Blue 750gb EnclosurePhanteks Evolv ATX Tempered Glass (graphite) | Cooling: Corsair H110i Case Fans: Noctua Industrial PPC PWM NF-A14
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2951572
carbide air 540
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2951692
http://www.bit-tech.net/hardware/cases/2013/06/19/corsair-carbide-air-540-review/3
Something like a RV02/RV05 is much better than the air 540. Newegg has it for 116$, the cooling performance is pretty much the same as the FT02/RV02.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163259&cm_re=silverstone_raven-_-11-163-259-_-Product
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2952813
This
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2952823
Anyone have any recommendation for a case that is the normal orientation and normal size?  Thanks for the recommendations so far!  I really appreciate it!  But, there just a bit "unique" and the size/shape of them is not optimal for my room setup.
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2953466
The Corsair 540 is a nice case, I'm just not really into the "box" cases. What do you guys have in mind for a mid or full tower case?
It's not so much a box as it is a slightly wide tower. It does look like a box in pictures, but it is taller than it is wider. (a box would be equally wide and tall, or wider than it is tall, at least in my mind).
You really cannot beat the air 540 for airflow. Except maybe the HAF Stacker 935 (because of it's modularity). MAYBE the Rosewill Blackhawk Ultra. but both of those are well above your given price range
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2961265
I'm pretty sure that these are the exact same but,  I'm not really looking for airflow, just a case that will keep my components the coolest.  Once again i'm pretty sure that the best case for airflow will be the best for cooling.  But just checking.  Thanks again.
https://linustechtips.com/topic/215257-best-case-for-airflow/#findComment-2961921
