CM Hyper 212 Evo
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/214358-cooling/#findComment-2932699
If you can raise your budget ever so slightly I recommend this cooler, I absolutely love mine:
http://www.ncixus.com/products/?sku=93616&promoid=1350
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/214358-cooling/#findComment-2932703
212 evo
https://linustechtips.com/topic/214358-cooling/#findComment-2932718
Hello, I was wondering is there any cheap air cooling and or water cooler. Budget: under 50
Cooler Master Hyper 212 EVO is what is recommended a shit ton around these forums, so I'll go ahead. Cooler Master Hyper 212 EVO
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/214358-cooling/#findComment-2932724
Hyper212 Evo is the king of budget coolers, and has been for some time. Beats low end 120mm watercoolers like the Corsair H50, H60, and Cooler Master Seidon 120.
On the other hand, damn that's a nice deal on the Dark Rock Pro 3. I might just buy that. Fuck da Intel Stock.
https://linustechtips.com/topic/214358-cooling/#findComment-2935268
