Best case for watercooling
Go to solution Solved by Anthony10,
H440, Define R4, Phanteks Enthoo Luxe/Pro would be good choices
Phanteks Enthoo Pro
It can fit a 420 rad on the top and even more elsewhere.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
Arc midi r2
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
+1 for the Enthoo Luxe.
It has a built in D5 mount, as well as mounts for reservoirs, and that should pretty much say it all.
I have the Enthoo Primo, and the build quality is great! (The screwbox they include is a really nice touch)
