Hi
i tried to overclock my cpu and as soon as i changed the frequency the computer started to restart itself on boot up.
it would start, shut down, start, shut down, then start and go to boot.
anyone know what the problem might be?
  • CPU
    AMD FX 8350 Eight-core 4.0GHZ
  • Motherboard
    Gigabyte GA-970A-DS3P
  • RAM
    Crucial BallistixSport 8GB 1600MHz
  • GPU
    EVGA GeForce GTX760 2GB SC ACX
  • PSU
    Corsair CX 750 W Modular
  • Cooling
    Corsair Hydro H60 v2
https://linustechtips.com/topic/213301-problem-with-overclocking/
Every time?
That's because it has to change its config, mine does too, just one time...
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
at least my mb resets all the settings after failed oc but its only good thing with bios that my msi z97 g55 mb has
it cant oc i5 4690k at all so i have to use shitty software
dont oc if you dont know how to do it and if you do that dont change any settings but essential
to compensate instability increase voltage... nah i wont explain you
if you have haswel
for ivy bridge
but overclocking is basicly have same rules
if you have haswel
for ivy bridge
i have a amd fx 8350
