My PC:
core 2 quad 9400
Asus P5QL PRO motherboard
2x 2gb ddr2
Gtx 260
What do you plan on doing?
Well it's either:
update GPU 1st
or
update CPU + MB + RAM
If you're planning to get a whole new system, I'd get the GPU 1st.
That way you'll see an immediate difference in game performance.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
get a 660 or a 270 GPU. I don't know if your system can handle more. if you're running a resolution below 1080p, than a 750Ti will be fine. Not much point to upgrade anything else, except maybe storage or ram, without upgrading everything.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
Upgrade everything, but first the GPU, and do not get a beefy one or the CPU will bottleneck it ;)
If he's going to upgrade the CPU later, why not get a beefy GPU. Even if it gets bottlenecked at first, it will be worth it in the long run.
Old shit no one cares about but me.
I would go with the GPU. The CPU is plenty for a few years more. I still got one running with a R9 280X and no bottlenecks.
