Best AIR CPU Cooler
Is it just about the same with the Noctua, The Phantecks PH-TC14PE and be quiet dark power pro 3 fit my build well, its a white and black build. Are they just about the same with performance because the Noctua is more expensive than the other 2.
They have about the same performance, I believe the best and most quiet is the Noctua - hence the price.
There are quite a few tests and benchmarks with all of those: here and here for example. I believe there are plenty more out there so you can also look for them.
They say Noctua will give you new mounting brackets if you ever need them. Phanteks has many colors. The be quiet! is the best looking for me.
It's up to you and your budget. If getting the NH-D15 will be tough to pay, get a cheaper one for sligh difference in performance. Also consider the NH-D14.
You won't regret any. Good luck with your choice.
Off-topic: I don't know how good are the included thermal pastes from Phanteks/be quiet! so it might be worth getting an aftermarket one if they are not "as good" as Noctua's.
