PSU help?
Pnudran
Go to solution Solved by extremescouter,
The Corsair AX760i would be a good choice.
I am looking for a fully modular PSU that I will be using for a micro atx  (short term temp build for my wife)
I am looking in the 500-750w power range. 80+ silver or better and SLI ready
best bang for the buck
I have searched around and all I have found so far that I like is this:
http://www.amazon.com/gp/product/B003RRY9RS/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
BUT it is a bronze. other than that I like it
you should look into seasonic or corsair.
what models? I have looked and cant find one thats filling the bill
also thank you for the fast reply
you could go for what extremescouter said or the seasonic x-series 750w 80+ gold. its fully modular
AMD Athlon 64 x2 3600+ | Asus M2N68-AM SE2 | 3gb ddr2 | Orion 600w | Sapphire HD5570
thanks for the help guys. going to be using the corsair, I will be having a corsair h100i so yea.
i second that!
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
