Hey guys im looking to start streaming csgo could you tell me what stream software i should use and my settings.
Intel i7 2600k
Asrock z77 extreme4
16 gb 1600 corsair vengeance
600w zx series coolmax
2 wd caviar blue 500gb in raid 0
xfx r7 260x
running windows 7
http://www.speedtest.net/my-result/3742024300
https://linustechtips.com/topic/210921-am-i-able-to-stream/
your internet's more important than your specs, what your internet speed?
Specs
https://linustechtips.com/topic/210921-am-i-able-to-stream/#findComment-2863063
Damn. That is some fast internet. It should be good for streaming.
totally not jealous of your internet speeds right now
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/210921-am-i-able-to-stream/#findComment-2863099
You'll be able to stream without any issues. :)
Previously Trogdor8freebird
5800x | Asus x570 Pro Wifi (barely enough for 64GB apparently given it's 2133 and still crashes sometimes) | 64GB DDR4 | 3070 Ti 8GB | Love that whole weeb shit
https://linustechtips.com/topic/210921-am-i-able-to-stream/#findComment-2863101
Holy poop, damn that's good.
You will be able to stream no problem.
https://linustechtips.com/topic/210921-am-i-able-to-stream/#findComment-2863103
At what bitrate and resolution
Max bit rate and buffer size should be 2500-3500 kbps. Higher bit rate and buffer size means better quality, but it also means that people will have to have a higher download speed to watch properly.
Also, you can stream 1080p @ 60 FPS with those specs without difficulty.
https://linustechtips.com/topic/210921-am-i-able-to-stream/#findComment-2863105
defiantly, i'm surprised that comcast has them speeds after all the shit they have been going through lately
Specs
https://linustechtips.com/topic/210921-am-i-able-to-stream/#findComment-2863134
It does not come cheaply or easily $300 and complains constantly about having slow internet and threatening to cancel unless they get there shit together xD
https://linustechtips.com/topic/210921-am-i-able-to-stream/#findComment-2863158
HDD speed and internet are the most curtial
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/210921-am-i-able-to-stream/#findComment-2863229
