Does anyone know how I can fix the broken power connectors (8pin+6pin) on my Sapphire R9 280X Dual-X OC? I can't RMA it because it was a power surge because of a power outage.
"Instinct or Rationality; Which will you choose? Enchanted by a superiority complex"
"what you do in spite of internet speed is inspiring. :3" From Cae - 2015
https://linustechtips.com/topic/210001-amd-r9-280x-help/
nothing you can do sadly bud. RIP 280x 2014-2014
Specs
https://linustechtips.com/topic/210001-amd-r9-280x-help/#findComment-2850209
seriously guys use surge protectors.... i have had probably 20 black outs and everything is fine. Also what has actually happened? have the connectors melted or is the card just broken
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/210001-amd-r9-280x-help/#findComment-2850212
UPS are very rarely needed and most the time over priced -_-
Specs
https://linustechtips.com/topic/210001-amd-r9-280x-help/#findComment-2850235
You can get a power board thing (the thing that splits 1 socket into 2 or more) with an inbuilt one not sure about the price though because my dad bought it for me :P
|| MAELSTROM ||
https://linustechtips.com/topic/210001-amd-r9-280x-help/#findComment-2850241
Most UPS have a built in surge supressor but you can just get a power strip with a surge suppressor. Its what I use
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/210001-amd-r9-280x-help/#findComment-2850315
Those are like $20.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/210001-amd-r9-280x-help/#findComment-2850522
