Say something like "there are plenty of fish in the ocean" but say it in tech/nerdy talk like " There are plenty of Games on steam" (maybe not the best one)
But say the real phrase then the tech/nerdy version
That way if you see a guy into tech you can cheer him up :D
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/20897-dating-advice-in-tech-terms/
I'm pretty sure I'm not the only one failing to see the point of this thread..
Just for fun jokes and what not.
You sure aren't.
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
In soviet russia origin eats steam
That's what i'm talking 'bout XD
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
I think the "There are plenty games on steam" analogy is apt. Some games are cheap, some games are good, some games are immature and not ready to be released. But at the end of the day, you still have to drop some cash to buy the game to play. Sometimes to play those games you need certain system requirements, like a minimum GPU and CPU.
EDIT: Or you can go to your buddies and play games with them.
Well you win the internet.
Remember children dont use torrents they might "infect" your precious areas. Always pay because you get quality and that gives worth to the "item".
Listen if you care.
It's simple
Put the floppy disk in the driver and download.
Coolermaster Scout 2 Case / ASROCK 990FX Extreme3 Motherboard / AMD FX 8350 8 Core CPU (Stock Speed) / Corsair H100i CPU Cooler / Gigabyte GeForce GTX 1060 WindForce OC 6GB / 16GB Corsair Vengeance 1600MHz CMZ8GX3M2A1600C8
Build Log: http://linustechtips.com/main/topic/20323-scout-2-update-build-fx8350-h100i/#entry244058
