Building 1st PC need help
Go to solution Solved by AlwaysFSX,
monitor... no. mouse, no. keyboard yes. windows yes. but i dont want to spend money on windows lol.
You can get Windows on G2A, but not everyone enjoys going to that route.
Here's a build that'll last a while.
CPU: Intel Core i3-4330 3.5GHz Dual-Core Processor  ($129.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Micro Center)
Motherboard: MSI B85-G41 PC Mate ATX LGA1150 Motherboard  ($69.49 @ Amazon)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  ($76.95 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.99 @ Amazon)
Video Card: Gigabyte Radeon R9 270 2GB WINDFORCE Video Card  ($169.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($49.98 @ OutletPC)
Keyboard: Microsoft SIDEWINDER X4 Wired Gaming Keyboard  ($59.98 @ OutletPC)
Total: $675.35
Generated by PCPartPicker 2014-08-31 19:53 EDT-0400
Total: $675.35
Total: $675.35
What can this run? Just to be sure.
most games at medium to high at 1080p
Specs
Sorry, the build list listed as answer on post. Sorry again.
The notes on that build (http://pcpartpicker.com/p/GpxXVn) seem fairly explanatory. The first says that the motherboard has a header which can be used if the case front panel has USB 3.0 ports. The case does not have any USB 3.0 ports. The second explains that the Windforce gpu is longer than 230mm and will block some drive bays.
Neither of these messages should be a concern for this build. Unless you want USB 3.0 ports (as opposed to USB 2.0 ports) on the case front, or you plan to mount 7 or 8 hdd in the case.
Thanks for the help. :) Also, is there anyway you could switch out the case that everything fits and it has 3.0 ports? Thanks again.
I'm not very tech savvy. Lol.
The motherboard has USB 3.0 ports on the back.
Can any more be spent to get a better case?
Yes. More can be spent to get a case with 3.0 ports.
Take a look at these: Fractal Design Core 3500, Corsair 200R, Corsair 300R, Corsair Graphite Series 230T Black, Fractal Design FD-CA-CORE-3500-BL-W and Corsair 230T Windowed-BLUE (there are actually several different color led models).
