@badogski29
Unless its a caselabs case or a 900D, then I would say yes. You'd be hard pressed in most cases to do a run longer than 50cm. Sorry about the pun, its just how it worked out.
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/206021-tubing-required/#findComment-2796231
I am planning to do my first WC build and i don't know how much tubing do i need. Ill have at least two rads and 1 block for the cpu and the gpu. Is 10 feet enough in my case??
10Ft sounds about just right. Most tubing runs will be less then 3/4 quarters of a foot long so you have ample lengths of tubing. What case are you using if you don't mind me asking.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/206021-tubing-required/#findComment-2796309
@badogski29
I had a 900D with 2 480mm radiators + 2 GPU + Cpu block + reservoir + pump
I only used like 6-7 feet total, 10 feet is a LOT of tubing, small builds would most likely only need ~3-5 feet if all the runs are measured pre-cut.
https://linustechtips.com/topic/206021-tubing-required/#findComment-2797779
thanks for all the reply peeps
I'm using an air 540, welp looks like its more than enough thanks again everyone. I just can't picture 10ft in my mind so thats why i asked.
https://linustechtips.com/topic/206021-tubing-required/#findComment-2798739
