Hey! I was wondering what graphics card i should go with its my first build and my budget on the card is max 450$.
Im gonna use the card for gaming (titanfall, BF4 and a few other games) but also for some light editing and 3D modeling (Cinema 4D).
I want to be able to run most games at medium/high settings 60FPS any ideas for a graphics card that can do that?
https://linustechtips.com/topic/203854-help-a-newbie-out/
AMD R9 290. http://pcpartpicker.com/part/sapphire-video-card-100362vxsr <-- this if you can spare another $15, it's the best.
There's also the Tri-X: http://pcpartpicker.com/part/sapphire-video-card-1003622sr
Twin Frozr: http://pcpartpicker.com/part/msi-video-card-912v308002
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/203854-help-a-newbie-out/#findComment-2767778
those games depends on your CPU too but i would say 280X,290 or 770,780
https://linustechtips.com/topic/203854-help-a-newbie-out/#findComment-2767783
How much does the 780ti cost?
If it's out of budget; R9 290X.
The Dude's PC Build<p>i5 4690k @ 3.5ghz w/ The Crappy Intel Stock Cooler | Asus Z97-K | 8GB Corsair Vengance LP DDR3 RAM @ 1600mhz |1TB Seagate Barracuda + 120GB Samsung Evo SSD | Gigabyte Windforce R9 290 4GB | 650 Watt CoolerMaster Gaming Series PSU | Bitfenix Shinobi Windowed | BenQ GL2460 | Corsair Vengeance K70 Cherry MX Brown | Razer Naga Hex Wraith Red gaming mouse | A £0.63 mouse pad from artcow.com
https://linustechtips.com/topic/203854-help-a-newbie-out/#findComment-2767791
R9 290. I'd go with a Tri-X or Vapor-X if you can afford it from Sapphire
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/203854-help-a-newbie-out/#findComment-2767809
R9 290 Tri-X is pretty good for the money, but if it's $10 more the Vapor-X is great.
https://linustechtips.com/topic/203854-help-a-newbie-out/#findComment-2767826
Welcome to the forum! :)
If you can, get an MSI Twin Frozr Radeon R9 290. You're going to play all games at ultra settings on 1080p or even 1440p.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/203854-help-a-newbie-out/#findComment-2767893
get an r9 290, but don't bother with Asus DirectCUii for 290/290x, or Gigabyte windforce either if you have any intention of overclocking.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/203854-help-a-newbie-out/#findComment-2767935
I second this statement
"We hold these truths to be self evident, that all men are created equal, that they are endowed by their creator with certain unalienable rights"
https://linustechtips.com/topic/203854-help-a-newbie-out/#findComment-2768468
