Aight. So I'm looking into a relatively high-end system to be my everything-able PC (video editing, gaming, general workhorse) and I was wondering what the best option of water-cooling would be - going for an all in one coolers or rigging up a loop to the CPU and graphics. A lot of people swear by the multiple loops to dissipate heat effectively using custom reservoirs and rads, where the people I know personally wouldn't go near anything so complicated and tell me to opt for the AIO solution.
I'm one to experiment and take things up a notch - so I was wondering what is recommended if I were to strike a balance between cost effectiveness and performance - regardless of time and effort.
I'd be looking at over clocking a high-end i7, and depending on the cost of plumbing opting for a liquid cooled GPU(s).
Is this a case of 'if PC cost is = or >$X, opt for the custom loop' - can the AIO solutions keep up, or is it purely preference?
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/
Go custom loop only if you can afford it.Definitely worth it but expensive.
H220-x is a great option though and it's also expandable.
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2758874
Custom loops have a much higher performance potential than AIO's due to expand-ability but also tend to be more expensive. For AIO though your best bet is the Swifttech H220-x as @SpyRosL already said.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2758884
Your post was not on my screen so deal with it :P
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2758944
Noctua air coolers can match up with almost all AIO liquid coolers, so you would be better off going with a custom loop if you can afford it.
i5-4670k @4.2GHz Sapphire Tri-X R9 290 @1135MHz 1600MHz G.Skill RipjawsX 8GB Samsung 840 EVO 120GB Samsung 850 EVO 250GB
Corsair K70 Logitech G502 Proteus Core Logitech G230 Blue Snowball SteelSeries QcK+
YouTube // Steam // Twitter // Facebook // Google+
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2758963
For AIO though your best bet is the Swifttech H220-x as @SpyRosL @SnowGhost1212 already said.
Y mad bruh?
jk.
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2758988
Only that air cooler is bulky and hideous in looks, and I mean absolutely hideous.
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2758994
Well, this is a tough one indeed. I've looked into air cooling, but - respectfully - they're not really my style. I can appreciate the affordability of them, however the space requirements or performance can't compete with an AIO or looped setup. Thanks for the suggestions guys - it really shows the optimal choice when everyone can be so coherent in suggesting the same cooler.  ^_^
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2759064
Then you have not seen graphs with the Noctua NH-D15. @5:07 you can see that the NH-D15 outperforms an H100i and the NH-D15 is an air cooler. Also the Kraken X61 is one of the best on the market atm and it only wins by a small margin so yes, air cooler CAN match an AIO.
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2766291
If you live in the U.S., there is an incredible deal on the Cooler Master Seidon 240M for only $60.  You will not find a better price to performance liquid AIO.  I have one and absolutely love it, the performance is incredible.
You can view my Review With Statistics here.
For GPU Cooling, you can always go G10.  I have a G10 with a 120mm AIO for my GTX 780 and that has exceeded my expectations.  ~$100 to liquid cool your GPU and never exceed 50C is a damn good deal.  A lot less expensive than custom loop and much easier to manage.  I was also in a similar position recently, deciding if I wanted to go AIO or full custom.  After comparing the two, obviously the custom loop temperatures are 10C better, but their price is much more expensive.  Keep in mind that custom loop requires a lot more maintenance also, especially if you ever wanted to change something, it requires you bleeding your loop just before being able to upgrade or change anything out.
I paid $56 for my CPU AIO and $120 for my Kraken G10 + X31 + Heatsinks, getting a water cooled system for less than $200 that never exceeds 50C while at 60% fan speed is a winner solution that you should consider.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/203250-aio-vs-looped-cooling/#findComment-2767966
