Hi there,
I have 32 GB of G.Skill 2133Mhz RAM and an ASUS PX79 Motherboard.
I don't know if the RAM is running at maximum speed so 2 questions:
1. Is this motherboard capable of running RAM at 2133MHz
2. Where ( i expect bios..) an how excactly can I change the speed?
Thanks for the help.
Windows 8.1 / i7 4930k / ASUS P9X79 / Gigabyte 770 4GB / Corsair H100i / G.Skill 32 GB 2133mhz RAM / Cooler Master V850 / 250 GB SSD C-Drive
https://linustechtips.com/topic/202797-ram-speed/
As far as I know you can only change the speed in the bios. UNLESS the mobo came with some software that lets you change stuff like that in the OS.
https://linustechtips.com/topic/202797-ram-speed/#findComment-2752167
It's most likely XMP RAM so you can go into the bios, go to ram settings and select the correct XMP profile. Otherwise you can download speccy to see if it is already running on 2133MHz (Will be displayed as approx. 1066 MHz because DDR). If it isn't just enable the XMP profile.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/202797-ram-speed/#findComment-2752172
In Asus X79 bioses  XMP is referred to as Ai Overclock Tuner, set this to XMP to run the memory at its rated speed and timings.
To check what speed your memory is running at, download CPU-Z and go into the 'memory' tab. Within the section 'timings' you will find dram frequency, which shows what speed your ram is running at. Dont get confused though, as it will show exactly half of the actual speed. Remember, DDR stands for double data ram, so just multiply the shown number times 2 and you get the actual memory clock speed. For example, if your memory should run at 2133, it will show something like 1066.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/202797-ram-speed/#findComment-2752260
This is what shows up! Weird....
But sometimes i changes to 600Mhz, so its not running at 2133Mhz.
Is my motherboard even capable of running it at that speed?
Cheers
https://linustechtips.com/topic/202797-ram-speed/#findComment-2762129
it will mean your are only running at 1333MHz default speeds
you will need to check in the BIOS for the settings
it will be in the menu where you can adjust the CPU speeds
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/202797-ram-speed/#findComment-2764353
But, can my motherboard run 2133Mhz? Where can I check that?
Yes it should be able to, but I think your cpu can bottle neck it
http://www.asus.com/Motherboards/P9X79_WS/specifications/
CPU: Intel Xeon E3-1240 v3 Motherboard: Gigabyte GA-Z87-HD3 RAM: 16 GB GeIL Dragon 1600mhz GPU: Gigabyte Windforce 770OC 2GB Case: Corsair Obsidian 450D Storage: 1TB WD, Blue, 120GB, munch ssd PSU: 600w Corsair
Display: aoc tn something, Dell ips U24..  Keyboard: CM storm quickfire xt Brown switches Mouse: Logitech G502, Pricing: http://pcpartpicker.com/p/8CBWjX
https://linustechtips.com/topic/202797-ram-speed/#findComment-2776474
