How to properly test pc parts before mounting into case
Solved by Accidentx13,
Use the cooler than didnt come with the CPU for testing due to testing your cooler. Also use your motherboard box if you dont have a test station. Nail polish remover works good instead of isopropyl alcohol if you have none. Use thermal compond that is either preapplied or apply some yourself
Featured Topics
Xrniu ·
7
3
bleedpurple ·
Posted in Storage Devices2 -
geoffery ·
Posted in Troubleshooting1 -
IPQ ·
Joey__ ·
Posted in Troubleshooting5
