Yo guys!
Looking for a new case... Something that looks unique, but at the same time has phenomenal airflow.
One case I'm interested in, is the 540 air... it looks phenomenal, and has room to grow. This needs to be able to fit a 7970, and an h100. (possible water-cooling in the near future). I really dont want to blow more than 300 on a new case... (considering my old one was over 300). It has stood the test of time (scratches on panels, etc,etc.
Ideas? :D
https://linustechtips.com/topic/202246-roomy-unique-case/
Case labs if you're a baller.
Case:Define R4 | MOBO:ASRock z75 Pro 3 | CPU:i7-3770k 4.0GHz | CPU Cooler:H100i | GPU:970 Strix | RAM:Hyper X 16GB |
Peripherals:ATH-M50x Limited Blue Edition | K95 RGB | M65 RGB | Blue Yeti MIC | (3x)1920x2080 Acer Monitors
https://linustechtips.com/topic/202246-roomy-unique-case/#findComment-2742868
air 540 is a great choice for what it sounds like you want it has tonnes of flexibility and is a bit different, i was looking for the same king of thing, i found myself torn between 3 cases, air 540, nzxt switch 810, and nzxt phantom 630. I wanted a window and just a window nothing with funny shapes and stuff thats hard to see through, all of them are a bit different with good flexibility and expansion, although for your budget if look at the phantom 820. I got the nzxt switch 810 due to the fact i managed to find i really good deal on one with damaged packaging and i got it for like 60% off, that how i decided between them.
Hope this helps
https://linustechtips.com/topic/202246-roomy-unique-case/#findComment-2742869
Hope this helps
Thanks for your input. I kind of have a broken heart with nzxt. My first case was a nzxt zero... and I don't know if I could ever go back
https://linustechtips.com/topic/202246-roomy-unique-case/#findComment-2742922
Inwin 904
This, or ft04, ft02, ft05 rv05, rv02
https://linustechtips.com/topic/202246-roomy-unique-case/#findComment-2744260
Node 804. Its a twin chamber design but for mATX boards only.
Fan mounts are virtually everywhere with support for up to 3 rads at the same time.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/202246-roomy-unique-case/#findComment-2745427
