Hi,
I just bought metro last light and i get only 3.8 fps according to RivaTuner.
In the little cutscene at the start i get around 30 fps but as soon as i go in te the start menu it drops to around 3.8 fps.
I have tried to lower the resolution to 800x600 and lower al other graphics options but seems to have any effect, I also tried to uncheck the advanced PhysX option but i didn't do anything.
My Specs:
  • MOBO: MSI z87 g45
  • CPU: Intel Core i5 4670k (Not overclocked)
  • GPU: MSI GTX 770 2g TwinFrozr OC edition
  • RAM: Corsair Vengeance 2 x 4gb 1600MHz
  • PSU: Corsair CS 750M 750watt
  • OS: Windows 8.1 64 bit
Any help would be much appreciated!
https://linustechtips.com/topic/201583-metro-last-light-low-fps/
make sure you have updated it.
https://linustechtips.com/topic/201583-metro-last-light-low-fps/#findComment-2733370
That game is weird everything gets low FPS even a i7 4790k and a 780ti
Really? runs lovely for me
I can run it on  high/very high at around 60 fps at 1440p
https://linustechtips.com/topic/201583-metro-last-light-low-fps/#findComment-2733396
Make sure you have SSAA set to 1 another issue I get like that sometimes is it's some weird fullscreen window mode issue. Does alt+tab in and out of the game have any effect?
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/201583-metro-last-light-low-fps/#findComment-2733401
Do you mean the game itself?
I am assuming you own the game on steam. If yes, it is updated.
Other than that you should have the latest drivers, especially GPU drivers.
Did you try running it with the absolute minimum settings?
Last thing: you can go into The nvidia settings and assign your GPUs to a .exe manually. I say GPUs because your CPU has it's built in iGPU which of course performs terribly in Metro LL. Maybe The wrong GPU is assigned when you start Metro LL
who cares...
https://linustechtips.com/topic/201583-metro-last-light-low-fps/#findComment-2733450
try disable physx and tesselation
https://linustechtips.com/topic/201583-metro-last-light-low-fps/#findComment-2733576
Yes I bought it on steam and i have just updated all my drivers and yes all the graphics options are now set to a minimum but no still no increase in fps.
and I'm not sure on how to assign my GPU to a .exe is it through the Nvidia Control Panel and then in the manage 3d settingst tab, if so that didn't help either.
https://linustechtips.com/topic/201583-metro-last-light-low-fps/#findComment-2733616
Yep, thorough the nvidia control panel. If that doesn't work I'm out of ideas. :(
who cares...
https://linustechtips.com/topic/201583-metro-last-light-low-fps/#findComment-2733774
