Built a budget PC for my little bro, it worked fine for a few hours, now won't turn on.
Solved by Unclescar,
After resetting the power supply the computer turned on. It turned out to be a corrupted BIOS, but after a BIOS reset everything is back to expected. I took a few steps in attempt to avoid the problem again in the future so we'll see, however it is not a power supply issue like I originally thought.
I'll keep an eye on it and be ready to put more effort and money into it in the future.
