I am planning to build my next computer myself and these parts looked good in this price what do you think?
My budget is 1000-1100 euros and i live in Finland i have the os and a display already.
PCPartPicker part list: http://pcpartpicker.com/p/dGTV23
Price breakdown by merchant: http://pcpartpicker....23/by_merchant/
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($187.98 @ SuperBiiz)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  ($119.99 @ Amazon)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory  ($89.98 @ OutletPC)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($77.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($55.98 @ OutletPC)
Video Card: Asus Radeon R9 280 3GB DirectCU II Video Card  ($208.99 @ SuperBiiz)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: Corsair CSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($85.99 @ Amazon)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($14.99 @ Newegg)
Case Fan: Fractal Design FD-FAN-SSR2-140 66.0 CFM 140mm  Fan  ($10.99 @ Newegg)
Keyboard: SteelSeries 6Gv2 Wired Standard Keyboard  ($79.99 @ NCIX US)
Total: $1012.86
Generated by PCPartPicker 2014-08-18 12:59 EDT-0400
https://linustechtips.com/topic/200725-my-first-build/
For one, that is in US dollars and that is from US retailers that ship to the US, so if you are in Finland you need to either use an  international retailer or buy the parts locally. Specs wise, you can do much better for 1100 Euros. PCPartPicker doesn't have a Finnish version so I cannot help you.
EDIT: As @SimpleG said, maybe German or  Italian or another European country on PCPartPicker?
Roses are red, violets are blue, computers are awesome, and so are you!
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721507
Total: $1012.86
Do you want to overclock? You may want to get the 4690k if that's the case. Other than that and the AMD card (I have a bad history with them, so go ahead and ignore if you want, i'm sure the card is fine), you ought to be fine :)
Linus once unboxed a Toblerone
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721524
Thats about 1040 euros in the store that i will buy the parts from.
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721529
Maybe but if i want to oc i have invest in a cooler.....
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721535
not necessarily. The stock cooler will do fine for a small overclock in a decently cooled room. I wouldn't recommend it, but it's possible.
also, there are good coolers for cheap (at least in the US)
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721543
Is ok, but u dont need a z chipset if u dont plan to overclock, so maybe this one...
http://pcpartpicker.com/p/9WCvD3
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721545
Very nice for a first build
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721554
i use Dutch Part Picker and Little Bit Over Budget
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  (€199.90 @ Caseking)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€31.63 @ Amazon Deutschland)
Motherboard: MSI Z87-G41 PC Mate ATX LGA1150 Motherboard  (€83.76 @ Amazon Deutschland)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory  (€84.89 @ Amazon Deutschland)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  (€64.90 @ Caseking)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€50.39 @ Pixmania DE)
Video Card: Asus Radeon R9 290 4GB DirectCU II Video Card  (€398.75 @ Amazon Deutschland)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  (€87.97 @ Amazon Deutschland)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  (€56.74 @ Amazon Deutschland)
Optical Drive: LG GH24NSB0 DVD/CD Writer  (€16.73 @ Amazon Deutschland)
Case Fan: Fractal Design FD-FAN-SSR2-140 66.0 CFM 140mm  Fan  (€12.99 @ Amazon Deutschland)
Keyboard: SteelSeries 6Gv2 Wired Standard Keyboard  (€88.70 @ Amazon Deutschland)
Total: €1177.35
Generated by PCPartPicker 2014-08-20 11:05 CEST+0200
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721602
R9 280X Version
Motherboard: Asus Z87-A ATX LGA1150 Motherboard  (€104.81 @ Amazon Deutschland)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  (€224.89 @ Pixmania DE)
Total: €1024.54
Generated by PCPartPicker 2014-08-20 11:08 CEST+0200
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721618
R9 280X Version
Total: €1024.54
That looks better i cant go over 1100.
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721633
you mean 1110 dollar ?
it under 1100 euro
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721640
it's under 1100
Total: €1024.54
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721642
Ok this is what i came up with:
PCPartPicker part list: http://pcpartpicker.com/p/gR6jRB
Price breakdown by merchant: http://pcpartpicker.com/p/gR6jRB/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.67 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($139.99 @ NCIX US)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory  ($89.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($87.98 @ OutletPC)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  ($79.99 @ NCIX US)
Power Supply: Corsair CSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($74.99 @ Newegg)
Total: $1098.54
Generated by PCPartPicker 2014-08-20 05:20 EDT-0400
ignore the pricing its about 1075 euros
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721682
Total: $1098.54
sorry i would say get the 280X Not 280
https://linustechtips.com/topic/200725-my-first-build/#findComment-2721710
  • 4 weeks later...
Ok the parts have been ordered now and my computer will look like this:
 PCPartPicker part list: http://pcpartpicker.com/p/qxTFCJ
Price breakdown by merchant: http://pcpartpicker.com/p/qxTFCJ/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($217.25 @ TigerDirect)
CPU Cooler: Thermaltake CLP0605 79.3 CFM CPU Cooler  ($28.50 @ Amazon)
Motherboard: Asus Z97-K/CSM ATX LGA1150 Motherboard  ($122.99 @ Amazon)
Memory: Kingston 8GB (2 x 4GB) DDR3-1600 Memory  ($94.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($85.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($56.98 @ OutletPC)
Video Card: MSI Radeon R9 280X 3GB TWIN FROZR Video Card  ($284.99 @ SuperBiiz)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  ($89.99 @ NCIX US)
Power Supply: Thermaltake Smart 630W 80+ Certified ATX Power Supply  ($78.96 @ Amazon)
Total: $1060.64
Generated by PCPartPicker 2014-09-14 12:39 EDT-0400
This is about 1090 euros ASSEMBLED.
https://linustechtips.com/topic/200725-my-first-build/#findComment-2947721
