Good day guys. Quick question. I've been searching the net for this topic, but I keep finding only the comparison between distilled and deionized, nothing on sterile/sterilized water.
Is it ok to put in my WC setup? Any downsides / precautions when using sterilized vs distilled? Thanks
this is the sterilized water i'm talking about
post-109039-0-84614900-1408371680_thumb.post-109039-0-48769000-1408371695_thumb.
https://linustechtips.com/topic/199737-sterilized-water/
Sterilized may contain minerals
Deionized may still contain organics
Distilled is the only free of everything but water.
Deionized can still be used interchangeably with distilled, however. Biocide or kill coils will prevent growth of whatever organisms if any are present in deionized.
Error: 410
https://linustechtips.com/topic/199737-sterilized-water/#findComment-2707221
Took this from ehow but the explanation seems reasonable.
"Water can be both distilled and sterilized.Distilled water is made through the reverse osmosis of water. Some uses of distilled water are in automotive cooling systems, steam irons and home aquariums due to the lack of minerals and impurities. Sterilization of water requires boiling or treating the water and is often used when water is not otherwise safe to drink."
So the water might contain impurities like minerals.
Then I should just leave this be, and get a distilled water?
https://linustechtips.com/topic/199737-sterilized-water/#findComment-2707224
Demineralized water is also ok.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/199737-sterilized-water/#findComment-2707338
I would not use it as i can make out how the sterilization was done. It could be that it was just boiled for a period of time at a certain temperature but it could also mean that an additive was put in the water and you don't know it corrosion will increase so don't use it...IMO.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/199737-sterilized-water/#findComment-2707588
