Best Graphic Card Manufactures in order.
CyanOG
What cards would you rank as the best I'm currently using a Asus Card no problems with it so far and they always seem to have the best reviews from users out of all cards
Other cards that I see always get good reviews : MSI,Gigabyte,Sapphire,EVGA the rest look like a mixed bag .. You guys would know better though
MY RIG | AMD FX-8320 | COOLER MASTER HYPER 212 EVO | ASUS M5A97 R2.0 | CRUCIAL BALLISTIX SPORT 8GB DDR3-1600MHz | WD CAVIAR BLUE 1TB | ASUS RADEON R9 280 3GB DIRECTCU II | CORSAIR 300R | CORSAIR CX 600W 80+ BRONZE | 1x COOLER MASTER SICKLEFLOW 120mm | WINDOWS 7 ULTIMATE 64-BIT | DELL S2240M 21.5' 1080p <p> | G602 | G710+ MOBILE| ONEPLUS ONE 64GB RUNNING OXYGENOS  | NEXUS 4 16GB RUNNING LOLLIPOP | NEXUS 7 2013 32GB RUNNING LOLLIPOP
Nvidia
AMD
OH YES I DID
But on a serious note, Sapphire, MSI and ASUS are the best at custom stuff, EVGA very close behind with the classies but most of their cards are reference PCBs with custom coolers on.
For the best built card of the current day? I'm actually going to give it to the Sapphire Vapor X design cards, they are outstanding.
Snapping at the heels will be the MSI lightning cards.
Nvidia
AMD
OH YES I DID
uh oh
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
They all of there ups and downs, theres no one real right answer
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
uh oh
Nvidia
EVGA
Asus
AMD
Sapphire
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
So what are the flaws of Asus direct cu II I'm Curcious as its my card
EVGA
Sapphire
MSI
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
there has been issues with overheating and the cooler not performing well (Thats why im not getting an Asus, EVGA FTW!)
:P
Current
:P
Ah well its funny cause reviews for my r9 280 pretty much all say the cooling works perfectly. My friend he has a GTX 760 windforce which is also working fine .. 2 card manufactures I know for sure I can trust
How about we talk about the ones to not get:
Galaxy (don't like em) Zotac.
AMD:
Diamond
Add on to the list if you want.
This is my opinion from what i have heard from others.
I havent heard problems from EVGA or Sappire. that is why i picked it
Current
In looks EVGA and MSI kill Asus,Sapphire,Gigabyte are runner ups
Nvidia
AMD
OH YES I DID
Evgas warranty brings them ahead of the others in my opinion, MSi is a close second. Asus completely fucked the R9 cards therefor Gigabyte is also ahead of them. I'm sorry but the Lightning blows away any Sapphire card.
Oh right if we're talking about who's best to deal with that's EVGA every time.
Lightnings are awesome but the vapor X can run the 290/x cool and quietly and fast, I just really admire it but I prefer the lightning's looks.
What's wrong with R9 Asus cards :/ I don't get it I chose it over a Gigabyte because I heard way better reviews I heard there's some cooling problems but not with my specific one
If you put the lightning on water which you would expect with any top tier 290x it will blow it away. If you're crazy and do LN2 or phase change then it really is no competition.
They literally took the cooler from the 780 and put it on the 290(x). It isnt made to deal with that kind of heat and runs almost as hot as a reference cooler
1: EVGA
Last place: Everything else
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
Yes I agree, I was looking at them from the perspective of using the supplied coolers, I would see it as an option but I wouldn't expect everyone who buys one to watercool, I had a 580 lightning on air myself, and a lot of people watercool reference cards also.
I see the coolers on my 280 are big so that's good.
The 280x is the same as the 7970 which had little to no issues
I've used PNY more than EVGA, last time I had an EVGA card they refused to RMA in... it was a 680 hydro copper. Right now since im #PoorPeople im using a PNY gt 630 and have gotten a 200 MHZ OC on the core and on the memory and it's actually pretty good for the price i paid for it.
Its the 280 not the 280x
