I just bought used Sapphire Radeon R9 280x Vapor-X. And when i start Battlefield 4 my PC just turns off, no blue screen or anything like that. And if I want to turn my PC back on i have to unplug my power cable for about 10 seconds and turn it back on. I tried 14.4 and 14.7 beta drivers and nothing helped. The temperatures both on CPU and GPU don't go above 60°C.
My PC:
AMD FX-8320 not overclocked
8 GB 1600 MHz Kingston memory
Asus M5A97 R2.0
Sapphire Radeon R9 280x Vapor-X not overclocked
Samsung 840 EVO SSD
To us were left the wonders of creation: Beasts of air, water, earth... and steel.
https://linustechtips.com/topic/198217-r9-280x-problem/
What does windows event viewer tell you?
https://linustechtips.com/topic/198217-r9-280x-problem/#findComment-2687724
Forgot to mention, it's some random LC Power 600 W PSU.
thats the problem, we have the exact same pc nearly :P, i had a 850w ezcool cheap shiz and samething happened, got an 80plus bronze boom no crashing, i could almost guaruntee its your psu
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/198217-r9-280x-problem/#findComment-2687806
I thought about that too, either it's my 280x or a PSU because everything was working fine with my old graphics card.
https://linustechtips.com/topic/198217-r9-280x-problem/#findComment-2687842
psu is my bet i had the exact same problem its power hungry, especially with a 8320 too
My Setup :P
https://linustechtips.com/topic/198217-r9-280x-problem/#findComment-2687854
Yeah I think it's the PSU too. I will get a new one as soon as possible :)
https://linustechtips.com/topic/198217-r9-280x-problem/#findComment-2687910
