Introduction:
So, this will be a diffrent Define R3 Build, it will be one with custom watercooling and a SR-2 motherboard.
There will be no crazy modding, and I will try to ceep the exterior as original as posible.
Components:
Evga SR-2 Owned
Dual xeon x5670 Owned
Dual gtx 680 4gb Owned
24gb G.Skills Trident x Owned
Seasonic Platinum 1000w Owned
Define r3 Owned
Crucial m4 128gb Owned
Crucial mx 100 256gb Owned
Watercooling
Duall EKWB cpu blocks Owned
EKWB SR-2 Blocks Owned
Alphacool NexXxoS Monsta 240 Owned
Alphacool NexXxoS Monsta 360 Owned
5x nb eLoop fans Missing 1
Aurora Gemini Pink coolant (not going to run the system with this over a long time, just for show) Owned
Alphacool VPP655 Owned
Bitspower Pump & ress config Owned
Bitspower Multilink fittings Owned
Duall Aquacomputer kryographics 680 Owned
Heatkiller backplate Owned
Misc:
Pink, purple and black sleeving Not owned
Htpx Mobo tray Not owned
Acrylic Not owned
To do list:
Stripp down the case Done
Test fit to see if there is space Done
Make som sort of bracked to the front rad Not done
Bend the tubing on the mobo Not done
Make a side panel window Not done
Create a mount for the psu Not done
Make a new floor in the case Not done
Make a new back for the case Not done
Make custom cables Not done
Cover up the front io ports and fix the front pannel Not done
Fill the loop Not done
Enjoy some 4k gaming! Not done
And now for some pics:
Still warranty on the card :)
https://linustechtips.com/topic/198163-project-cramped/
nice shorts. i have green ones with flowers.
https://linustechtips.com/topic/198163-project-cramped/#findComment-2686940
You want to watercool two GTX 680s and two socket 2011 CPUs in a Define R3 with a enormous motherboard? Could you please include what you have done to the case to fit all your stuff? :D
Edit: at least i see why you've chosen that title. :)
who cares...
https://linustechtips.com/topic/198163-project-cramped/#findComment-2686975
I have a huge amount of shorts like that, They are really comfy
not 2011, 1366 :P
But right now I havent done annyting other than stripping down the case internally, will rebuild it to mount all the stuff.
But its actually not as bad as I had imagend with space in the case. I feared it would be much more cramped that it is. :)
And cooling is not going to be an issue, there will be an 360 rad and an 240 rad, bought 80mm thick
https://linustechtips.com/topic/198163-project-cramped/#findComment-2687020
not 2011, 1366 :P
Oh good lord, 1366. :D
Please update your OP stating 'EVGA Classified SR-2' and 'Intel Xeon X5670'. That might clear some confusion that I and maybe other might have. :D
I see that cooling won't be an issue, just getting it in will be. I'm subbed for more :)
who cares...
https://linustechtips.com/topic/198163-project-cramped/#findComment-2687098
I'm a lazy person, updated now, it were a few extra presses to make the name more presice as i wrote the op. :P
https://linustechtips.com/topic/198163-project-cramped/#findComment-2687150
Update!
Just got the gpu waterblocks.
Need to get shorter screews to the backplate or make som spacers, to make the backplate and gpu block work together, but they will! :)
And one thing i noticed when taking the phantom cooler apart:
Thats some sort of oil, that explains why the card runns hot as hell!
What the heck are gainward thinking?
And now for some cleanup, why is it so f'ing hard to ceep everyting organized?
https://linustechtips.com/topic/198163-project-cramped/#findComment-2716644
Wow, that's a nice looking backplate! I wish you luck on this build, i look forward to seeing it come together :P
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/198163-project-cramped/#findComment-2716671
  • 4 weeks later...
Update!
Got the ram and psu!
Now i need to make it pink :D
But daimn thats some good looking ram! :)
Yeah loving the backplate. Need to get some other screws to make it fit though
https://linustechtips.com/topic/198163-project-cramped/#findComment-2958596
getting closer :)
https://linustechtips.com/topic/198163-project-cramped/#findComment-2958950
:o awesome
|CPU: Intel core i5 3570k @ 4.5GHZ |Motherboard: Asus Z77 -V lx2 Full atx |RAM:Kingston HyperX Fury 2x8GB DDR3 1866MHz |GPU: 2 X ASUS AMD Radeon HD7850 2gb Crossfire |Case: Corsair Carbide 300r |Storage: Western Digital Caviar Black 2tb2 Samsung 840 120gb ssd raid 0 |PSU: Seasonic 750w 80+ PSU |Display: lg 32" 1080p 60Hz |Cooling: Noctua NH-D14 + 4Noctua NF-P14 scythe Kaze Q-12 Fan Controller |Keyboard: SideWinder X6 |Mouse: Razer DeathAdder 2013 |
https://linustechtips.com/topic/198163-project-cramped/#findComment-2959645
Aww man that dual socket board *drool
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
https://linustechtips.com/topic/198163-project-cramped/#findComment-2967137
