Does too much watts exist?
Go to solution Solved by dragoon20005,
nothing will happen
you are still drawing 500 watts from the 1000 watts your PSU can supply
No, it will just waste money on your power bill.
he wont be wasting money on power bills
Let's say I only need a 500w PSU. But I but i get a 1000w one anyway. Will anything bad happen?
No, it will just waste money on your power bill. But if the psu is poorly built then it might fail and might take your components with it. I suggest getting a good brand like Corsair, EVGA, and Seasonic.
EDIT: IGNORE ALL OF THIS
No it won't...
Nope, nothing bad will happen.
nothing will happen
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
You won't, If you're PC uses 400W, it will use 400W, regardless if you have a 500W PSU or a 1000W PSU (Not calculating in efficiency ratings).
What are you talking about?
500w or 1000w won't make a difference if it's a shitty PSU
You'll have spent more on the power supply than you needed to, emptying your pockets unnecessarily. If you are only using say less than 20% of what the 1000W power supply can deliver, the efficiency curve may decrease quite a lot. What that means is if you are idling or watching movies or YouTube videos a lot, you won't be using much power, and the 1000W PSU may be less efficient than you expect. Ultimately, it doesn't mean much. You'll lose probably a couple dollars in wasted electricity. The real cost is the up front cost of the power supply.
sml_gallery_52341_1555_25613.pngBelow 20% load, efficiency often drops more than you might expect.
IDK MUCH ABOUT PSU
Then don't post ignorant comments.
IDK MUCH ABOUT PSU
Why are you commenting about it then...
No, electricity does not work that way
If the computer only needs 500 watts, only 500 watts will be drawn from the power supply! if it only needs 50 only 50 will be drawn (well there will be some loss due to inefficiency which is typically 80%)
Running a high watt PSU at low wattage is less efficient though
Sometimes this can be good, because some PSUs have a silent mode when under low load. But it is a waste of money
IDK MUCH ABOUT PSU
Then why are you giving advice. You know you have real responsibility, right? You're advice impacts their purchases and other decisions, and could waste their money, time or damage their components even.
Hopefully you realise a 500W unit that is 80% efficient at 100% load pulls 600W from the wall, delivers 500W, and loses 100W as heat. A 500W unit can (or should) be able to deliver the full 500W. Efficiency doesn't take away from that.
I know that.
That is why I wrote "(Not calculating in efficiency ratings)".
