I have a iPhone and I want it reset to factory settings...
But, when I try to do that it asks for passcode that I don't known...
So, tell can anyone tell me what should I do?...
Thanks,,,...
Plug it into iTunes and do it through there
https://linustechtips.com/topic/192277-iphone-help/#findComment-2605184
click restore iphone. i hid my number because i don't need tech support :P (it's a joke, don't be a bitch about it.)
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/192277-iphone-help/#findComment-2605257
how the hell do you survive with 16 GB lol, I have 32 and its barely enough
I have around 300mb space left even after using 256kbps AAC, which is the lowest is ever go. I'll wait till the iphone 5 32GB go to around $400 then I might get it
https://linustechtips.com/topic/192277-iphone-help/#findComment-2605985
What are you putting on your phone that takes up 32 GB of space? I have 8 and I've never once had a problem. But I also don't dump my entire itunes library onto my phone if I won't listen to 99% of it on a day to day basis
https://linustechtips.com/topic/192277-iphone-help/#findComment-2610779
Tons of music and quite a few games
Song Of The Day: Nujabes - Battlecry
https://linustechtips.com/topic/192277-iphone-help/#findComment-2610826
I can guarantee that much music isn't necessary. I used to have an iPod with like 15k songs on it but most of them I never listened to it. And I guess I don't think any iPhone games are worth playing, I usually put my phone away when I leave the house and if I'm home I have my PC. But that's just me
https://linustechtips.com/topic/192277-iphone-help/#findComment-2610905
I need this much music and im constantly needing more lol, and have you ever tried Plants vs Zombies 2?
https://linustechtips.com/topic/192277-iphone-help/#findComment-2610985
Need? You listen to (lets call it 20GB) of songs on a daily basis? I find that impossible to believe. Yeah it's alright but there's never a time when I'm out of my house and only have my phone with me when I want to play games. Usually if I'm out I'm socializing or working so I won't be playing games.
https://linustechtips.com/topic/192277-iphone-help/#findComment-2611046
