Strange noise from GPU, then PC won't power up
Solved by Coollok100,
Try using a different PCIe 3.0 slot?! Not sure what motherboard you have. I can help you but need more info. Hopefully you do not have to RMA motherboard : (
I stated the motherboard in the opening post. I managed to work out what the problem was - the 24 Pin connector was loose at the power supply end (not sure how that happened....). Anyway, the system is running fine now, and I've done some stress testing and all seems good.
