i plan on overclocking my 4690K not to any extreme values but still a significant amount. I'm stuck on what cooler to buy. I originally was going to buy a cooler master seidon 120v however after reading various reviews it seems to have a noise problem as well as not providing the best cooling. I'm currently looking at a corsair h100i, but does this provide a good performance to price ratio? The NZXT krakens seems quite interesting but still not sure.
I have a corsair 760t
Edited by hmminteresting
CPU: R9 5900X----GPU: RX 7900 XTX ------MOBO: ROG X570E-------RAM: CORSAIR VENGANCE 32GB-------PSU: SEASONIC 1000W-------CASE: LIAN LI O11D XL ROG
https://linustechtips.com/topic/191261-cpu-overclock-cooling/
Performance:
H100i < x41 < H105 < H110 < x61
But I have the H100i because I wanted corsair link. Performance is definitely not bad at all, and its not far behind the others.
https://linustechtips.com/topic/191261-cpu-overclock-cooling/#findComment-2581818
Get X61, Swiftech H220, or the Option of the Money, Noctua NH-D15 or just a D14 if you can't spend over $80, it's performs slightly less than the D15, but way better than the H100i/110
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/191261-cpu-overclock-cooling/#findComment-2581853
kinda set on liquid cooling. does the performance of the X61 justify the additional price?
https://linustechtips.com/topic/191261-cpu-overclock-cooling/#findComment-2581875
