Oh that type of mate I thought you were talking about a cpu
yea....anyway the i5 4690K cpu is better than the 4670K since the temps are a bit better this time.
My PC
[ I5 4690k (no oc) - Gigabyte Z97 D3H - 8GB Ram - Sapphire R9 280X Vapor-X ]
You are under absolutely no obligation to overclock any CPU, that said if you are not going to overclock you should buy the no K version so you can save a little bit of money.
Unlocked just means it is overclockable.
Also, while again you have no obligation to, you should buy an aftermarket cooler, most, if not all will be quieter and better performing than the stock Intel cooler.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
So is there an alternative I5 that might be great for gaming
As far as I know 4690 and 4690K are same CPU. One can be overclocked and other one cannot. So in that sense 4690K is best as you can, if you like, improve its performance by overclocking it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
You seem to be very novice with computers i would suggest you save some money and just buy an haswell refresh CPU that is a locked chip (non K) along with an H97 motherboard, all of those can run any games on max settings...
here i put 3 kits for you with 3 different price, the performance gets a little better at every step-up, so pick the one that fits your budget, as i mentionned they all perform great okay and you do not need an after market CPU cooler:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($179.99 @ Newegg)
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard  ($79.99 @ Amazon)
Total: $259.98
Generated by PCPartPicker 2014-07-28 15:08 EDT-0400
________________________________________________________
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($198.97 @ OutletPC)
Motherboard: MSI H97 Guard-Pro ATX LGA1150 Motherboard  ($98.99 @ Mac Mall)
Total: $297.96
Generated by PCPartPicker 2014-07-28 15:09 EDT-0400
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($214.99 @ NCIX US)
Motherboard: MSI H97 GAMING 3 ATX LGA1150 Motherboard  ($116.99 @ Amazon)
Total: $331.98
Generated by PCPartPicker 2014-07-28 15:10 EDT-0400
See the CPU is clocked a little faster as you go up in price, you can pick wichever board you might want with any of these cpu's.
Pair that with 8GB of DDR3 RAM (1600mhz is good enough) and put the rest of the money in the best AMD GPU that you can afford (R9 280, R9 280X or R9 290) and you'll have a killer gaming PC.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
