help with 92mm radiator fan
Solved by Shaqo_Wyn,
so be quiet fan is not good?
if i am buying from newegg can i trust them?
Be Quiet fans are good too, are they better than Noctua? IMO no. Yes you can trust Newegg. http://www.newegg.com/Product/Product.aspx?Item=N82E16835608027
Featured Topics
Shadow1789 ·
Posted in Cooling3 -
7
1
5
3
INotPablo ·
Posted in CPUs, Motherboards, and Memory9 -
Marie Rose ·
Posted in Cases and Mods6
