general help !
Solved by Archangel1994,
Also as for the files you need to download. From those 62 files (liiterally lol) the ones you want are:
Chipset: Intel Management Engine Interface V9.5.15.1730 for Windows 32/64bit 7 & 32/64bit 8 & 32/64bit 8.1.(WHQL)
Audio: Realtek Audio Driver V6.0.1.7218 for Windows 7/8/8.1 32bit & 64bit.(WHQL)
LAN: Intel LAN Driver V18.5.54.0 for Windows 7/8/8.1 32bit & 64bit.(WHQL)
USB: ASMedia_U3_FW_update
Those are the mandatory ones (I assumed you have 8.1 64-bit)
The others are optional but quote me if I missed anything.
