Hi,
I'm wondering how to make my Corsair RM 850 PSU look a little better.
Are there any PSU covers that either look nice, or light up? Or must they be handcrafted?
I'm interested in stickers aswell, I have an EVGA "enthusiast built" sticker that came with my GPU.
I'm interested in all mods, regardless of brand.
Is there ex. some PSU cover tha lights up, that is available to buy ready?
Thanks.
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/
What case do you have?
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/#findComment-2511954
PSU covers have to be fabricated to fit your case specifically so there isn't really one you can just buy, if your interested get a sheet of 3mm plexi and a heat gun to bend the plexi, afterwards if you want to light it up either frost the plexi using spray frost or a frost plexi sheet.
Alternatively if you want you could carbon fiber or vinyl wrap the exterior to give it a cleaner look, just don't' cover any vent holes.
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/#findComment-2511968
A black PSU, so it can hide in the case and never have to be looked at.
What do they know of England, who only England know?
"Well that's what I always said I wanted to be remembered for, for being honest. Nothing else is worth a damn"
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/#findComment-2511986
A Corsair 760T-windowed chassis: google it and you'll understand why I'd like to do this!
I don't think anyone makes retail PSU covers. you could try to paint it.
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/#findComment-2512001
For my CX600M I just peeled the stickers off and cleaned the adhesive with rubbing alcohol.
looks a lot better in an all-black build without the green stickers
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/#findComment-2512147
Hmmm I never thought of that one, I'll try it!
Thanks!
note that if it affects your warranty, I will not be held accountable
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/#findComment-2512459
I decided to just leave my RM series PSU alone. I have a 760 too, and I figured just about anything I do to it will make it look odd.
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/#findComment-2542779
You could try cutting some colored plexi glass with certein paterns to make it look nice. Vinyls would probably work too but they have to be heat resistant or they will peel off again.
Peeling off the sticker won't void you warranty imo. The one that they care about is the little one that sits over one of the screws that hold the unit together, so you can't get inside. ;)
who cares...
https://linustechtips.com/topic/186533-psu-aesthetics-mod-help/#findComment-2553382
