little bit of help with oc please
Solved by Queek,
That sounds like something that Load Line Calibration would do. Do you have it on Auto in your bios? If so, set it to something in the middle range that your motherboard allows (each motherboard is different).
If you want more info on LLC, read the link in my signature.
Featured Topics
Crash The Noise ·
Posted in Programs, Apps and Websites2 -
2
7
Shadow1789 ·
Posted in Cooling3 -
7
4
