GTX 680 SLI problems/non SLI problems too
hmm...that's odd. Honestly I've never had that happen, going into safe mode when a driver install fails pretty much always works. It must have partially installed and tries to run and basically breaks. The windows CD option seems to be a sound move from this point. I'm terribly sorry that the driver instal went tits up, I hate when that happens.
had to reinstall the OS. after that it did boot up into windows and i tested out both of the cards and found out which one of them doesnt work.
i didnt have any spare pci-e brackets so i had to put in my gtx 560 so there doesnt come in an immense amount of dust into the case.
also i play alot of borderlands 2 so i suppose that helps by having it dedicated to physx
Going to send in the one that doesnt work to that guy and get half of my money back.
